Hi, I have developed this tool that allows you to remove audio/subtitles tracks, that you do not need from MKV videos. The tool supports batch processing. It also allows you to select the tracks you need based on language(s) or track numbers/IDs. You can find the project in here:
https://github.com/samehb/MKVStrip
The source is there, too, in case anyone wants to add/change features/options.
If you have any questions or feedback, please use my blog (available within the project readme).
Feel free to move/modify/merge this post, as you see fit.
Regards.
looks kool!
suggestion : can you please update with a progress bar or time elapse feature to let us know it is not hung?
-thx -
Need Help Batch Remove Audio,Remove Subtitle,Change Default Audio and Sub
By Inoyama in forum Newbie / General discussionsReplies: 9Last Post: 9th Jan 2018, 16:20 -
Batch remove audio streams and subtitles from several mkv?
By samus88 in forum AudioReplies: 3Last Post: 30th Dec 2016, 03:56 -
How do you remove audio from videos using VSDC?
By Amber25 in forum EditingReplies: 1Last Post: 28th Jun 2016, 04:00 -
Any tool to remove soft subs?
By Djard in forum SubtitleReplies: 9Last Post: 17th Oct 2014, 01:33
